-   -   hydraulic valve adjustment procedure (https://www.offshoreonly.com/forums/general-q/387456-hydraulic-valve-adjustment-procedure.html)
35fountain 02-18-2026 10:27 AM
hydraulic valve adjustment procedure, flat tappet or roller
Hi, I was wondering if anyone ever adjusted their rockers this way. I did one engine and start up was quiet and ran nice. I need to do the other.. I found this way super easy. No worries on where the cam lobe is, what cylinder your working on or firing order your at. Comp cams says do the way when the exhaust valve begins to move adjust the intake. Then when the intake is fully open and begins to close adjust the exhaust. You know that way your going to be off. I have done it that way for many years and I always had a noisy valve train. A little tougher in the boat especially pulling the plugs but I think it's worth it.
Thanks in advance
F-2 Speedy 02-18-2026 11:36 AM
No, I do mine in the firing order no need to go back to every nut multiple times
Tartilla 02-18-2026 04:35 PM
Firing order SBC/BBC
1843
7572
When cyl 7 rocks int/exh smae time...adjust cyl 1. Both lifters will be on the base circle. Take up the slack in the pushrod...add your pre-load turn...whatever it might be for your specs/needs.
Carry on with rocking on 5...adjust 8. Etc.
Pull the plugs out to help bar over
SB 02-18-2026 05:33 PM
Never seen that way.
I’m old, not gonna’ change my way that i’ve used with no issues since the dinosaurs roamed the earth. :)
cyl by cyl.
int valve just closes - adj that cyl’s exhaust
exh valve just opens - adj that cyl’s intake.
kinda long version of adj valves but you can do it pretty quick
compedgemarine 02-18-2026 06:02 PM
interesting engine you have there Tartilla, never seen one with two #7's. but yes we know what you meant.
I have always done it like SB, spin the pushrod to find zero then adjust each one. may take a little longer but I know where I am on each and as said, I have done it forever so not changing now.
Tartilla 02-18-2026 10:21 PM
Yeah...my meat hooks often get out of bounds...doesn't help that Android pulled spell check, and a mistake isn't highlighted.
This method works for solid lifters as well...where you need to set a lash on the base circle.
JaniH 02-19-2026 01:41 AM
https://youtu.be/CDQ_JhMlDz4?si=moxiGk2QNmC_Yzrv
Thanks in advance
I saw this video few years ago, and Have been doing IT like this since. Much less chance For error.
Brad Christy 02-19-2026 08:47 AM
Guys,
This was the method I used.
Thanks. Brad.
Wally 03-04-2026 07:53 AM
So the thread triggered my memory and i had to go looking through my "shop notes" i scribble down on loose papers and store in a pile of random stuff on my tool box :D
Anyway i found this note i made a long time back that sounds the easiest....... but have yet to actually try this:
The easiest way to adjust rockers is to set #1 cyl to TDC (both intake and exh valves will be closed)
then you set the intakes valves on 1257 and the exh valves on 1348
then rotate 360* and cyl #6 should be on TDC (both valves closed)
and you set intake on 3468 and exh on 2567
and your done.
Brad Christy 03-04-2026 09:16 AM
Originally Posted by Wally (Post 4943749)
So the thread triggered my memory and i had to go looking through my "shop notes" i scribble down in loose papers and store in a pile or random stuff on my tool box :D
and your done.
Wally,
.... Assuming no firing order swaps. Otherwise, alter cylinder order accordingly.
Honestly, I never know this was even a thing until my 496 rebuild.
Thanks. Brad.
