8.2L engine knowledge
I'm looking at another boat that has 8.2 l, 380hp catalytic engines. These engines have closed cooling and have been running in freshwater. Question...
1. How many hours should an engine have before a top end is performed? 2. When should the exhaust manifolds be changed? 3. What do you have to do to make a 8.2L, 380 HP engine 430HP? Computer flash? Thanks |
these engines will run well over 1000 hrs before major overhaul. Manifolds, IMO, are dependent on where it's run. I just traded my 496 with 550 hrs. on it and never did the manifolds. I just inspect them.
I think there's more to it than a flash. I wanna say cam and other stuff.... |
Originally Posted by MonkeySea2
(Post 4944632)
Originally Posted by AmiableDave
(Post 4944560)
1. How many hours should an engine have before a top end is performed? 2. When should the exhaust manifolds be changed? 3. What do you have to do to make a 8.2L, 380 HP engine 430HP? Computer flash? Thanks Not at all the same engine, but the only real differences between the 496MAG and the 496HO is the cam and the ECM flash. I'd imagine it's the same with the 8.2. Thanks. Brad. |
Here is some good and bad about these engines, dont know what year engines you are looking at, maybe mother Merc have these fixed ?
https://www.offshoreonly.com/forums/...er-engine.html |
1. How many hours should an engine have before a top end is performed? 2. When should the exhaust manifolds be changed? 3. What do you have to do to make a 8.2L, 380 HP engine 430HP? Computer flash? |
I was kind of surprised these run two ECU's..........one for engine management and the other for emissions and they are linked together through some type of gateway.
(Post 4944679)
| All times are GMT -5. The time now is 12:44 PM. |
