-   -   A question for the PROP SHOP PEOPLE... (https://www.offshoreonly.com/forums/general-q/39566-question-prop-shop-people.html)
KAAMA 12-24-2002 11:29 AM
I have read that the Bravo One 4-bladed props are more of a stern lifting prop. If this is true, is there anyway to reverse this so that I can get more bow lift? I have a 32' A/T with Stellings extension boxes.
Help! :confused:
Thanks,
Mark/KAAMA
JaayTeee 12-24-2002 11:55 AM
mark,
whats your prop rotation?
turning the prop's "in"
will sometimes give added bow lift,
but it WILL result in poor
handling issues around the dock.
i alway thought the bravo 1 was
suppose to be a bow lifter?
cleaver, or pointed ear (intimidator style)
were stern lifters?
i have experienced, from going to 3 blades
to four blades of both types, the feeling of
more stern lift, or inabilty to carry the bow,
but saw photo's of the boat running later,
it was still carrying the nose, but the whole
boat appeared to be running higher, and faster :D
my .02
jt
obnoxus 12-24-2002 12:36 PM
Sure,, get 3 blade labbed Mirage Plusses !!!!! ( sorry :-) )
KAAMA 12-24-2002 01:09 PM
As far as manufacturers go, I thought the highest pitch that a Mirage Plus 3-bladed prop makes is a 29"------am I correct???
Whiteknuckle 12-24-2002 01:24 PM
Kaama,
On my particular boat, which is single engine, I did notice a considerable amount of stern lift with a Bravo as compared to a Mirage or Mirage Plus. I did like some characteristics of the 4-blade but I stayed with the Mirage Plus.
RumRunner 12-24-2002 01:42 PM
Whiteknuckle:
What were the pro's & cons (on your boat) with the four blade ? What size did you try ?
Ric232 12-24-2002 03:14 PM
Re: A question for the PROP SHOP PEOPLE...
Help! :confused:
Thanks,
Mark/KAAMA
Mark, compared to a Mirage Plus, the Bravo 1 is a little bit of a "stern-lifter." But compared to most other 4-blades out there, i.e. Hydromotive, the Bravo 1 carries the bow quite well. If you don't have hull steps and your x-dimension is fairly conservative, you could run 3-blade Mirage Plus's, but you'll probably want to go back to 4-blades. They tend to spoil you, even if you do lose a little speed. Oh, and yes, Mirage Plus's max out at 29P.
Griff 12-24-2002 03:15 PM
Kamma, I talked to Darin at Houston Prop about doing the same things to my prop just a couple days ago. Basically, he said that thinning the trailing edge will reduce stern lift and adding some "rake" and cupping in the right places will increase bow lift.
I think that Bravo 1's are about the least stern lifting/most bow lifting 4 blades you can get. I did see a prop similar to the B1 on Hydromotive's website--QuadIV-X that says it give added bow lift for conventional V bottom boats.
Whiteknuckle 12-24-2002 03:32 PM
RumRunner,
The comparison I made was between a 25" Mirage Plus and a 26" labbed Bravo. I liked the way the Bravo came on plane, cruising at 3000RPM was actually a little faster than the Mirage and the Bravo seemed to bite better in a turn. However at High speeds with the Bravo I did get noticable stern lift, and the boat felt uncomfortable from what I was used to. I did not like the feeling. Joe at the Sunsation Factory, always recommends the Mirage for the Rocket/Aggressor.
28Eliminator 12-24-2002 04:58 PM
RumRunner,
I had the same thing happen on my boat as Whitenuckle did. Only I had 23 Mirage + and a 24P Bravo. The mirage was slower out of the hole, but felt very stable and was faster, about 2mi.
The Bravo made the boat fell like is was skidding on ice, out of control. Now I have a whipple and am running 28 & 30 lab Bravo's, but if I could use a 3 blade I think it would go faster. It doesn't feel loose anymore though, with the bigger prop. I am actually faster with 1/2 - 3/4 full of fuel. My only guess is that
it distributes the weight to the back and I get more bow lift.
KAMMA, It looks like we need to talk to HOUSTONPROP or throttleup. Maybe they can give us some ideas!
