Who sells exht tip trim rings?
Looking for the ones with the rubber gasket and NO tip. Used with floating 4" tips. Seen them with a gray colored gasket.
thanks Dan |
stainless marine or stellings
IMCO
Dan, I had bought some IMCO's from JimV for my Scarab, they have a stainless ring with a urethane type center that allows the pipe to move, they worked great, seems like they were around $60.00 a pair.....Fred
DAN!! How be you this bright new year? Tell me what's a good time to call and yak for a while.
Fred
Thx..I'll call Jim as soon as I know exactly what I need Crazy Call home in evening..after 7 is best BTW Superbowl trip is canceled so I should be here Dan |
Are you expecting any company during the Miami boat show? I'll try to call tonight after 7. Dave
The IMCO number is FK-66...(Silicon gasket with S/S Flange 7" OD X 5"ID)....check with Jim on that to be sure though......Fred
Check them out on; www.imcomarine.com
No company during the boat show that I know of..you thinking of coming down then? That would be a good time. I plan on going thurs nite after work or fri morn, comin home sat nite.
Dan |
Couldn't find anything....
Well gang, I just went to the IMCO website and I sure didn't see any of these tailpipe rings. I looked both in the Performance Hardware section and the Exhaust Systems and parts section and could NOT find anything within these two sections. They did show something simular to it but it looks as if you have to buy the exhaust tip with it if I am not mistaken.
Here's a link to Gil marine with pictures and specs.
http://www.gilmarine.com/products/transom/index.html |
I got the part numbers above from a IMCO parts book that I have, I think is a year or two old.....maybe they don't have them anymore......Fred
trim rings
CP PERFORMANCE has them. They are made by "Hardin marine".
Look under exhaust/ accesories. |
I have 8 of them with rubber rings in my garage is your willing to re-poweder coat them. Drop me a line if interested.
-Greg |
| All times are GMT -5. The time now is 03:33 PM. |
