Difference between 500efi and 575Sci
Looking to learn some here, What is the difference between these two besides the 256cid Holley/ weiland, and compression ratio?
Are their differnt internals, heads, cam, springs,?? Thanks:rolleyes: |
here are the specs for the 500 EFI
http://www.mercurymarine.com/hp500_efi_-_470_hp and the 575 http://www.mercurymarine.com/hp575_sci_-_550_hp This might help alittle :) Travis |
Traviss,
I went through the specs and only diff it lists is as follows 575= TBI, comp 7.50:1 and weiand 256, 92 oct required 500= MPI, comp 8.75:1 87 oct required I am really curious is the blower the only differance?? their has to be more to justify the cost?? |
Boating magazine had an
article on building the 575, i will try to find it when i get home tonite, but some of the differences I do recall were: 575 flat tappet hyd. cam, the already mentioned compression difference, and shorter connecting rods ??? With mercury marine horsepower is exponential with $$$$ jt |
Oh yeah, the oil filter screws on an additional 1/8 of a turn on the 575. That oughta be worth some $$.
The 575 is a hand built blueprinted motor while the 500EFI bottom end comes preassembled from GM powertrain like the rest of the black Merc motors. Im sure they justify some of the cost from this fact. Still pricey though.
Ron |
| All times are GMT -5. The time now is 10:14 PM. |
