-   -   question on sea pump/fuel pump (https://www.offshoreonly.com/forums/general-q/41427-question-sea-pump-fuel-pump.html)
H2Xmark 01-19-2003 04:34 PM
Need some help here, I have a 29 outlaw with twin 454mag- efi's, it is a 1997, I pulled the sea pumps with the fuel pumps[mechanical] still on the sea pump, I changed out the impeller housing and impeller every thing is going great, then I saw fuel spill out of the vent? tube that the clear yellow hose hooks to on the fuel pump, I also saw a plug on the fuel pump drive that is a fill plug i am guessing, I think the fuel pump diaphragm is blown? and what kind of oil or fluid goes into the fuel pump drive at the front of the sea pump,[it has a combo of gas and oil in it] it has a little sticker near the plug that say's something about see mercury engine manual , any idea's ?
Mark
mtm 01-19-2003 04:52 PM
fuel pump oil
the oil to use is mercruiser high performance gear oil .same oil they use in the bravo drives
H2Xmark 01-19-2003 06:32 PM
ok, I have some of that stuff left over after the service i did on my drives, can you use synthetic ?
US1 Fountain 01-19-2003 06:39 PM
Yep, Merc geal lube. Wouldn't know why you couldn't use the synthetic stuff though. And yes, it does sound like your pump went south.
