Heads,,,,Oval or Rectangular ??????
Ok guru's looking for some opinions.I already have mine but would certainly like to hear everyone's opinion...
509Ci,naturally aspirated motor.I'm running rectangular now! What are the pro's and con's between oval port and rectangular cyl. heads..?? I have heard many differences. I would also like what differences there would be between the 2 if they are both Stock GM. heads. Meaning I'm not talking aluminum,although feel free to give opinions on those too! So,lets get this discussion going |
It is my understanding that the oval ports can generate more horsepower than the rectangular ports. BUT, the ovals require a lot of work to get there... stock, the rectangular port heads are better, but harder to find than ovals. Total performance goes to the ovals though.
It depends
The rectangle port heads will be better at high rpm with large camshafts and high compression ratios. Over 6,500 rpm, 12.5:1 compression ratios and camshafts with over 250 degrees intake duration @ .050. This is the type of racing engine Chevy had in mind when designing the rectangle port heads (not marine engines). Any engine built with less will work best with oval port heads.
Dennis Moore |
Hello, Guys,
I am an oval fan on less than 500cid, less than 6,000rpm, maybe even bigger, depending on other factors. I have run the Merlin ovals with great success. They do need a litttle cleanup in the pockets, but almost anyone with the will to do it can. I have seen several boats succumb to the theory "bigger is better", take off the Merlins I installed and replace them with almost ANYTHING else, and loose power through the rpm range-I vote OVAL. Keep in mind, though, some OEM heads suck without work-maybe a LOT. Tell us which and I'm sure you will get help!!! Have a deal if you will pm. |
I'm not sure which is better but my ovals seem to work very well. I use Edelbrock oval ports that have been worked over by the Chapman Racing family. They are about the largest ovals you can get and are probably over 300cc after the head work.
I run these on my 540 ci with a 232/240 114 .600/.600 Ultradyne cam with 9.2:1 CR and the motor is at it's very best around 5400 rpm. I don't know if it would run any better with rectangles ;) This setup will be getting a 5 lb boost in the very near future. This should be a good thread. :) Dave |
Dave,,,now your talking about blowing a motor? In my opinion that is when you would want to run rectangular heads..Again,just my opinion...
blown1500,I am trying to compare stock heads.See below for reason. Here is the reason I brought this whole question to the table...I am now running square port heads.Inconel valves,and was about to get them bowl blended...Now a buddy of mine has a STOCK set of oval ports(big chamber) that are mine for the asking...All I would have to do is transfer over my valves and stuff.He would then take my rectangular heads... So the cost to me is "zero"...But,is there any advantage ? |
The data I gave you was for my motor naturally aspirated; not blown...
Sorry for the confusion, Dave |
Originally posted by NordicHeat The data I gave you was for my motor naturally aspirated; not blown... Sorry for the confusion, Dave Sounds like your going to be adding a blower though. Correct ?? |
Can we bring mercruisers choice of rec port on motors stronger than 310-330 stockers. Seems to me that mercruiser invested loads of dyno time in these engines and rec port seemed to suit thier needs. I think that the head port design has changed on the newer mag engines (gen VI) and are a vortech style of port. So i am refering to gen IV and V. If I am wrong, please point this out.
I went Merlin oval on my 502 and glad I did. Cam 224-234 110 lsa installed on a 110.My Merlins came with 2.25-1.88 valves and I got them through Summit.I wish now I had ordered them through World.I think they would have put in the extream inconel exhaust if I had asked them as they came with the sever duty exhaust .The best thing I could say is get Dennis Moore's book it will lay it all out very clearl,around here it is known as the Bible.:cool:
Washed Away. Mercruiser used rect port because it was the only head available besides the truck peanut port head. The large oval heads have not been made since the 70's.
Hello, 1Boatnut,
Most GM ovals will not run with the rectangular without work. Some will never measure up. We need to know the casting number or at least approximate year, which combustion chamber(open or closed), which piston you have............. Without enought info, though, you are taking a chance trading heads. I would not do it until I had confirmation on what I'd be getting!! Good luck no matter what. Post or pm and i/we will help all we can!!! Oh yea, Formula31, I think, is correct about why they used what they did. They generally use whatever GM has that can be adapted:D |
ok he said stock Gm oval to stock Rect. port, with a 509 and a good size cam, if you turn this motor to 5400 rpm's are more go with the rect. ports, but I am no expert,
Mark |
Mark::) :)
Some stock ovals were pretty good, but I don't think they will do what he wants with that many cubes. The aftermarket or maybe a set of "049" casting number heads with mods will. Without the mods, I think I would go with the rectangles here. :D :D |
blown1500,,,I think I have to agree with staying with my square ports..Like I said the only reason I was asking was because I can get the STOCK ovals for free from a buddy of mine and he swears by oval ports....
If I were to go ovals,I would probably go with aluminun heads.. Thank's for all your info. If I decide to go aftermarketI'll give you a shout. |
Any idea when chevy switched to peanuts? I'm thinking that peanuts are oval port castings with a smaller plug in the intake port. I know peanuts are a zero on the performance scale, but why did the chevy gods changed to this casting? Seems that a standard oval would meet their needs in a truck head.
Just a curious mopar guy, Washed Away |
1Boatnut,
yes I am adding a supercharger. I do however boat at 4000-6000 feet which adds a few more variables to head selection; blown or natural. Dave |
Washed Away!!
The "peanut port" head got it's name because the ports are about as big as a peanut. The smaller the port, the better they work untill you need more air than will go through them. If you want hp, that means more air. Chevy made these heads for trucks wilth a red line of about 4,200rpm. The main goal was very low rpm torque. Cleaned up, these are great in the proper application. They won't, however, feed most of what we use in a performance boat. I don't remember the year they went to the peanuts, but many of the guys here will know. It was in the 70's I think Nordic Heat, the blower REALLY helps up there!!:) |
I hope so :D :D :D
I think '84 was the last year large ovals were available as an OEM Chevy part. That left small ovals and rectangles as the only options until 96 (I think). Any one know if the '84 and older standard performance 454 from mercruiser made more than 330 hp at the crank with large ovals?
| All times are GMT -5. The time now is 02:54 PM. |
