-   -   Any one know the cam specs and compression ratio for stock 502's? (https://www.offshoreonly.com/forums/general-q/42160-any-one-know-cam-specs-compression-ratio-stock-502s.html)
GNJ2 01-29-2003 10:12 AM
Looking for specs on 1998 502 MPI motor
Brad Perry 01-29-2003 10:28 AM
8.75:1
FloridianSon 01-29-2003 06:47 PM
I'm showing GM cam #12551622 or Mer.#431-8510478 is 224 224 duration .483-.483 lift 115.5 LSA
FindMe 01-29-2003 08:54 PM
Boy, are you ever missing out..... Here ya go, just click on the prop!
http://home.attbi.com/~fordhater/PROPELL.GIF
Dennis Moore 01-29-2003 09:01 PM
Don't trust those specs!
I removed a camshaft from a Gen VI Mercruiser engine with roller lifters and sent it to Comp Cams to be measured and it came back with the specs Floridian Son gave.
Dennis Moore
audacity 01-30-2003 06:31 AM
mine was in the VERY low 8's when we measured....most were under 8 1/2. this was pre 96 when i was doing these.
ursus 01-30-2003 10:37 AM
The cam spec given by findme 211-227 .511-.511 were used on the gen 5 engines ( im not sure about mkIV) the newer gen 6 are 224-224 .483-.483
built to spec ( blueprinted) CR should be 8.75, mine measured out at 8.78 however have been told by a merc rebuild depot the factory engines are all over 8.5 to 8.8
mcollinstn 01-30-2003 10:24 PM
My MkIV 502 service manual shows identical specs as the Gen6 (224/224 .483/.483).
GNJ2 01-31-2003 07:09 AM
OK Thanks to everyone for all the replies.
Ric232 02-01-2003 10:52 AM
Okay, I'm confused.
My Gen6 service manual shows 511/511 lift and 211/227 duration. I believe the 483 lift cam is the Gen 5 cam.
