-   -   Paging John B:sideways carb mount ? (https://www.offshoreonly.com/forums/general-q/42294-paging-john-b-sideways-carb-mount.html)
PROFILE 01-30-2003 10:29 PM
When mounting a single carb sideways on on a 250 blower did you have to fabricate an adapter plate?
Thanks,Jeff
RLW 01-30-2003 11:11 PM
If you are mounting a 4500 series carb (Dominator 1050), the mounting holes measure the same front to back and side to side.
At least mine does.
PROFILE 01-31-2003 06:51 PM
RLW,
I was going to use a 4150 hp series 1000 cfm which the base is not "square". I did not realize the 4500 base bolt pattern is square.I'm sure fabricating a plate for what I'm trying to do would'nt be to hard,just thought maybe someone made a adapter " turn" a 4150.
John B 01-31-2003 07:58 PM
Profile, I was using a 4500 1050cfm, which was a square bolt pattern. I don't know if anyone makes the adapter you need. You could probably get a standard adapter and move some of the studs! JB
PROFILE 01-31-2003 08:14 PM
Thanks John,thats what I'll do,
Jeff
John B 02-02-2003 11:01 PM
Jeff,
Try to stay away from the older single circuit dominators, they have to be set up to run rich all the time, unless you change the metering blocks. I think the blocks are about $100 each.
John B
