-   -   Newbie ? re: Bravo (https://www.offshoreonly.com/forums/general-q/42328-newbie-re-bravo.html)
Donzi38ZX 01-31-2003 10:53 AM
Newbie ? re: Bravo
Ok this will certainly show my experience level with caring for boats. My question is what do I need to run the engines in my boat out of water. I know you can hook the hose to the drives but I do not know what adapter I need. Also where can I buy the equipment needed. The reason is I would rather do some of the work such as changing oil at my house before I put the boat in the water at the marina. My boat has HP500EFI and Bravo XZ Drives. Thanks.
Cord 01-31-2003 11:11 AM
Theres two ways. If you want to keep the hose external, there are some muffs that will go over the water pickup. The strut mounted pickup will take one that looks like two suction cups. The low water pickup takes one that fits over the nose. The second way is to disconnect the intake hose from the transom assembly, stuff the garden hose into it and tighten the clamp.
stevel 01-31-2003 12:01 PM
Or, you could install a fresh water flush system inside the engine compartment.
If you go with the muffs over the intake try to buy one with a wire going through the drive to make sure they stay in place. The others rarely move unless someone kicks the hose etc. but it is better to be safe than sorry.
Allways have the water running!
Turn the water on full blast.
Start Engine - don't run more than 1500 rpm or so
Stop Engine
Then turn water off
Extra water will gust run out the sides. Not enough water and you will burn up the rubber impeller that sucks in the water.
Happy flushing!
Steve
red racer 02-02-2003 11:59 PM
Here's a good one...
Needed to buy a new Bravo outdrive due to a submerged sand bar...
The new one's come with both high and low water p/u's... What adaptor do oyu use???? Side clamp with the wire, nose cone version or both.... :D
Red Racer
obnoxus 02-03-2003 09:29 AM
Red Racer
Take your pic,,, throw a little duct tape over the other holes, but keep an eye on it.
