-   -   Temperature Guage????? (https://www.offshoreonly.com/forums/general-q/42455-temperature-guage.html)
freeman1 02-02-2003 12:44 PM
HI everyone had a quick question. When I start up my boat my temp guage jumps all the way to the right side (After about 1/2 of running it drops back down to 160 Degrees). I have a VDO guage and 2 senders (One on the T-stat housing and one on the intake manafold)....How do I tell if it is a bad guage or a bad sensor?? I'm assuming since the guage jumps to the hottest setting when the motor is Ice cold that there is a problem somewhere.....
Chris
Vinny P 02-02-2003 04:40 PM
I have never heard of having 2 senders for 1 guage. I would think that there may be a feedback problem here. Try eliminating 1 sender and see what happens to the guage.
blue thunder 02-02-2003 06:07 PM
I had that same thing happen when I installed VDO senders with gaffrig (merc campatible) gages. The voltage reference was backwards so the readings started high and then dropped off. The second sender is probably a temperature switch for an alarm.
BT :cool:
ursus 02-03-2003 11:59 AM
The sensor on the intake manifold is for the audio warning system. The one on the Tstat is for the guage.
Standard VDO guages use senders which operate backwards 10-180 ohms versus US standard (merc) 240 -33 ohms. To confuse things more VDO also makes guages which are backwards and work on US sensors.
You need to match the sensor to the guage. Here is a list of VDO senders. Pick the base size, probably 3/8 or 1/2 NPT and the terminal type, probably spade. I am not vouching for the online vendor either way, have never used them but they have a good list of vdo part #'s
Sender Listing Link
