Prop Direction
Using TRS outdrives should the props turn inboard or out board and which way handles best or performs the best ??
Hotrod - Try doing a search for prop rotation. This has been the subject of quite a few threads.
My .02 - It depends upon the specific boat, power, loading, rigging, and personal preference of what "feels" good. Whatever, be careful testing since changing rotation can make the boat handle quite different in some cases. Good Luck! Jeff:cool: |
prop counter or clockwise rotation
JT500 you have posted on this one before where are you?:)
Sorry off subject, Darin Ihave a question I have a 87 formula 242 350hp alpha 1 1.5. I have a 4 blade bravo 22p I only get about 4200 rpms is it possible to re work this prop it is in nice condition price? time? really won"t need it till may . :( thank you mark [email protected]
repitch and custom Lab/masi242
masi 242 you need 600 rpm we will have to repitch the prop down 2" in pitch and reduce the dia a little ( MY SECRET ) Then thin out the blades and re balance to zero tolerance and put some cupping on the tips of the blades ,the turn around time right now is two weeks minium,and the cost with a satin finsh is 390.00 and to polish the prop it would total out to 490.00 it will blow out of the hole like a bullet and run great on mid and top end range also .shoot me a contact phone number and best time to call and I will be glad to call you back for complete details of work and pricing/Thanks Darin;)
Darin,
Like jbrauer has said, we talked about this a couple of weeks ago, and there's more about this in "search" Jbrauer, saw in another post a while back, that you were in the forklift biz, whats you equipment lines ? jt. |
jt - We are the Raymond forklift dealer for parts of TN, KY, GA, VA & AL. Are you familiar with Raymond?
Here's our website, but it hasn't been updated for a very loooong time! www.braueronline.com Jeff :cool: |
Jeff,
Were a Toyota, BT, Schaeff, and Advance cleaning equip. dealer for IA and parts of IL hupptoyotalift.com ( currently, under construction) Ever need any info on our stuff, PM me. jt |
forklift jt 500 hp
Originally posted by jt29olhp500s Jeff, Were a Toyota, BT, Schaeff, and Advance cleaning equip. dealer for IA and parts of IL hupptoyotalift.com ( currently, under construction) Ever need any info on our stuff, PM me. jt |
Darin,
different company, different building, building is next door to L&J, or should I say, old, L&J. L&J moved, building gone. jt |
Hotrod2
As long as the props are not spinning the same direction you will be fine. As for in or out that depends on the boat. I would not bother with changing rotation if the boat handles good. There are other ways to gain speed. Try different props and pitches. You my even want to take your props to a prop shop to have them worked a little. Check the bottom of your boat for any chips and dings in the gell. If your running nose cones make sure that they are smooth and no chips in the epoxy that bond them to the drive. Allso check drive allighnment they need to be perfectly parallel. I run bravo 1s on my 34 scarab and they work great. I tried mirage 3 blades and couldnt even get on plane. They kept blowing out. As for direction mine spin inwards. |
lorenz & jones marine dist.
Originally posted by jt29olhp500s Darin, different company, different building, building is next door to L&J, or should I say, old, L&J. L&J moved, building gone. jt |
To answer the question , spinning in is faster, spinning out handles better
My port spins ccw and sb spins cw. Is this considered spinning out? I run mirages as well Tom M. and have a little trouble getting on plane with a 30' Scarab. I always though I just needed a little cupping adding at the tips of the blades, more like a mirage plus. May try that this year. You think my 30 footer would run faster with the blades spinning the other way?
BT :cool: |
Blue thunder,
Yes, this would be considered spinning out. I would reccomend leaving the rotation as it is and going with a 4 blade prop like a bravo one. If your running around 365 hp per motor I would go with a 24 inch this will get you in the high 60s with no problem getting on plane. Like I said my 23 mirages were just awful getting on plane, after about a mile or two getting on plan I didnt see any differance in top end. Get the four blades and work them if you like. I my have a set of 24s for sale soon to move to a higher pitch. Any questions you can e mail me. |
Blue thunder,
I made a mistake about my rotation they spin outwards. I am dyslexic some time. lol. |
Thanks Tom. I am expecting 425 to 450hp (per) this year and believe I will be needing at least 26p hydomotive or bravo 1s. Going to let testing be the decider. I spun 25p mirages to 5100 with 365hps. 25p mirages with 330s got me 4700rpm last year. 27p miragesshould now be and option as I believe mirages give the best top speed, but are harder to get on plane. I personally like the mirages other than out of the hole, but wish I could try bravos, just to see.
BT :cool: |
Blue thunder,
30' scarab is a real good hull. If you got any pictures send them my way. I have got a 34 scarab and just love the size and performance of it. |
1 Attachment(s)
Here is my baby. Sorry for the picture of my monitor, but it is the best I can do until summer :(
BT :cool: |
Blue thunder
With 500hp a motor you will be able to spin 28 four blades and run close to or even 80mph. I know of a 87 panther with 500 hp motors TRS's and 28 four blades and he runs 80 on gps. For some reason that hull likes the four blade props, as due most scarabs our size. |
Boy Tom, I'd like to think 80 gps. My goal has been at least 75gps, and I think I'll get that. With the optimistic 450hp and bravo drives I may do a little better than I think. Would really like to find a place that will loan props for trial. I've been told the same thing about the 4 blade props and these boats. I have plenty of bow lift, so the stern lift of the bravo1 or hydromotive would probably really put it on top of the water. I need to do some testing this spring.
BT :cool: |
| All times are GMT -5. The time now is 10:10 PM. |
