-   -   Gear Ratio (https://www.offshoreonly.com/forums/general-q/42718-gear-ratio.html)
EliminatorBill 02-05-2003 06:28 PM
Gear Ratio
I recently purchased a used Teague Platinum drive from with a refurbished case, the seller thought the gear ratio was 1.36. After testing it on my boat, I have the ratio might be lower ... 1.26. Does anyone know how to determine the gear ratio on a drive ?
cobra marty 02-05-2003 06:55 PM
Count how many turns on the input shaft will turn the prop shaft 10 times and divide that number by 10.
15 turns give 10 prop turns = 1.5
13.6 turns give 10 prop turns = 1.36
12.6 turns gives 10 prop turns = 1.26
EliminatorBill 02-05-2003 07:45 PM
Thanks for your formula
