Head gasket/bolt upgrade
Hey All,
I'm having a Procharger installed and it's been recommended that I upgrade the head gaskets and bolts. Seems like a good idea (?), But I was quoted $800.00 for parts and labor, is that reasonable????? How many hours would you think it is and how much for good parts? Powerboatin...... Commmmmmmmmmon Summer......... |
That sounds very reasonable for a shop in Los Angeles. Where are you located?
Dennis |
Thanks for the reply,
I'm in colorado, the break down was $225.00 for bolts, $140.00 gaskets (including exhaust) and the rest labor = $435.00 ($55.00 hour). Powerboatin.......... |
In addition to the cost question, I was planning on replacing the heads and beefing up the motor next year anyway, sooo what is the likely hood of blowing a gasket (no pun intended) with the Procharger added?????
VERY good likly hood I would do the bolts ,,,but order the parts from summit racing ,,alot chaeper
Not bad - prices aren't but DOUBLE what they should be for the parts. It would sound a lot better if the price was for twins.
HEAD GASKETS $110.00
ARP BOLTS $142.00 LABOR SOUNDS GOOD I JUST DID THIS |
Sounds like a lot of folks need to shop at Jegs or Summit.
How much boost are you running? I ran a bone stock 7.4 with 9 pounds of boost with a ProCharger for 3 years hard.
Wow KCHOTBOAT,
From what I hear that is really good. I have now talked to several guys that have gone through head gaskets.... My buddy and I are both having Chargers installed and only planning to run 5lb boost. A 5lb pully at lower elevations and 7lb (=5lb) at higher elevations (3600-6000 feet) closer to home. Thanks for the advise everyone............ |
| All times are GMT -5. The time now is 06:13 AM. |
