502 engine flow numbers
In looking at heads how much flow will a 502 at 5500 rpm require.
Is the monstrous flow of some of the new head needed. Don't want to buy more than i need. thanks in advance |
You've got plenty already!
All 502 engines come with rectangle port heads and they are overkill already. Most performance increases at 5500 come from installing a smaller intake port head. Go smaller not larger. 290 - 310 cc intake ports are closer to optimum than the 320 cc heads already on your engine.
Sincerely Dennis Moore |
Well there you have it, right from the mac daddy Truckin himself. Go with smaller ports for max power at that RPM.
I agree with Truckin! Those stock GM rectangle heads are too big as they come!
| All times are GMT -5. The time now is 02:36 PM. |
