-   -   Lubes? (https://www.offshoreonly.com/forums/general-q/43832-lubes.html)
kathycool 02-20-2003 09:43 PM
Lubes?
What't type of grease to use on couplers?
Also what type of oil for weiand blowers on 525SCs?
mopower 02-20-2003 10:08 PM
Engine couplers or trailer couplers:confused: In either case I use the blue water resistant marine grease;) ( same as wheel bearings)
Can't answer about the Weiand blowers ....I'm not blown:o
Mear Image 02-20-2003 10:17 PM
Mopower, Why did you order them Boost guages? ;)
Mark
Now get back to work!
mopower 02-20-2003 10:45 PM
Mark,
SHHHHHHHHHHHHHHHHHHHHH....don't tell anybody:rolleyes:
Time to go home:D
Mear Image 02-20-2003 10:51 PM
Oh, That's right.. I forgot! I meant What about those clocks you bought. Boost gauges, Silly me..:D
Mark
Good night..
Griff 02-21-2003 03:45 AM
Re: Lubes?
Use the Merc High Performance gear lube in the blower. Same stuff that goes in the drive.
Griff 02-21-2003 03:48 AM
I should add, make sure you check both the front and back fills on the blower. They are completely separate. Change the lube out completely/as much as possible at least every 50 hrs.
kathycool 02-21-2003 08:24 AM
Thanx for the info,
getting ready for spring:)
