-   -   Drive Alignment??? (https://www.offshoreonly.com/forums/general-q/44017-drive-alignment.html)
25 Eagle 02-23-2003 09:12 PM
Drive Alignment???
I know that the drive should be aligned periodically but for what reason other than getting grease to the drive shaft u-joints? How would you know if it were out of alignment? I get a vibration sometimes as I am pulling the stick back and coming off plane, anyone else? I am going to have this service done with 150hrs but was wondering what the whole thing is about Thanks
Tinkerer 02-23-2003 09:47 PM
If the engine mounts get loose then the alignment of the engine to the boat and drive will change. If that happens then you will soon lose a drive coupling that costs about $180 and You have to pull the engine to replace it. The vibration you are feeling may be caused by loose engine mounts or poor alignment. I pull my drives and check my alignment every year.
