DesktopDyno users find my mistake
I plugged in all the stock #'s for a merc 525sc, but I'm not getting the right power #'s. My stock 454 mag came within 1 hp of its rated power when I ran it on desktopDyno. Heres a summary:
Engine: 454 4.251"x4.000" Heads: Stock Merc rectangular port cast iron Compression: 7.5:1 Induction: [email protected]"hg, Weiand 177, belt gear ratio 2:1, 55% eff Exhaust: default to Forced induction exhaust Camshaft: Crane#132561 530/551 lift, 298,306 advertised duration, using seat to seat |
What results are you getting?????? WOT operating range is 4800-5200rpms.
Desktop dyno horsepower estimates, stock 525sc:
4500rpms=444hp 5000rpms=486hp 5500rpms=510hp Way low #'s. Ive had good results with other motors. |
I'm guessing that #'s at 5200 are probably real close to 500hp. Based on that the desktop #'s are only off by 5%. I don't think 5% is THAT far off. Could it be the blower efficiency # or the exhaust causing the difference????
I know puder had an engine with pretty close to 525SC specs and it dynoed at 550hp+/-. If I remember, he had a little more cam and comp ratio. |
CAM TIMING
@ .050 Try this instead of Seat to Seat I'm guessing here so bare with me:D Try This link |
I've never gotten useful numbers with Dyno2000 using .050" numbers. Seat-to-seat has been much closer to known figures for known setups. Don't know why, but this has been my experience.
Seat to seat has worked best for me, but I'll experiment to see what happens with the 525 simulator.
| All times are GMT -5. The time now is 01:49 AM. |
