-   -   Hydro- trim pump (https://www.offshoreonly.com/forums/general-q/44896-hydro-trim-pump.html)
HOTROD2 03-10-2003 07:09 AM
Hydro- trim pump
Will the trim pump for the drives work on the K-tabs or are they a differant type pump ? They don't look the same, but the tabs have dual cylinders just like the drive trim. Anyone had any experiance with this? The drives are 1989 TRS, and the tabs are Merc's dual ram large Tabs 1989(keikhafer).
Mbam 03-10-2003 07:22 AM
They will work fine, just remember that the hi-pressure line on the pump = blue wire = down on the tabs.
HOTROD2 03-10-2003 07:28 AM
Thanks Mark, What is the proper way to bleed the air out of the system and what fluid sould be used?
Mbam 03-11-2003 07:01 AM
You can use just about anything for fluid, the spec has changed over the years. ATF or 10-30 oil is fine.
As far as bleeding, I just run the tabs up & down a few times. I have never done anything to bleed the system, even though it is not a bad idea.
