-   -   Appling Decals (https://www.offshoreonly.com/forums/general-q/45072-appling-decals.html)
Rick G 03-11-2003 08:50 AM
Appling Decals
I'm going to apply some pretty large Decals to the sides of my newly painted boat. Does anybody have any experience with this. I understand you should wet the surface before you apply the decal. What do you wet the surface with and how wet do you make it. Any help would be apprecoiated. Rick G.
Audiofn 03-11-2003 09:14 AM
Soapy water does it for me. Then give it about two days in the sun to dry. Not a problem for you up in the frozen tundra!! :D:D
Get a chance to get those pictures out? I have been swamped with work I will try and reply to your email this evening.
Jon
Cord 03-11-2003 09:38 AM
1 Attachment(s)
Wet the surface with some soapy water. The soap acts as a lubricant. Depending on the size and complexity you'll either peal the backing in stages or all at once. You apply the graphic and let it float on the water. Position and adjust it until it is perfect. Now start in the center and squeege the water out working twords the edges. I found the little plastic body filler applicators would leave tiny scratches in the vinyl surface. By putting a piece of the backer between the vinyl and the squeege you won't scratch the surface or move the graphic around as much. That's a key thing. You'll want to stop regularly and look to see if you are distorting the graphic. Don't let yourself make that mistake. Don't let the surface dry out or the graphic will adhere. If you see things starting to get dry, stop and remist it. As you go along, try to work out the blisters and any wrinkles. The blister can be difficult to get out if you get too far past them. I had some luck using a hair dryer to dry the water allowing the vinyl to adhere.
This is a pic of our first vinyl job.
Cord 03-11-2003 09:41 AM
1 Attachment(s)
Here are some instructions that I downloaded off the web.
1 Attachment(s)
...continued...
1 Attachment(s)
...yet another one...
Cord 03-11-2003 09:42 AM
1 Attachment(s)
...final one.
Dave M 03-11-2003 10:51 AM
Hey Cord,
Did you get those graphics from Raceline Digital? I was considering them for mine.
Cord 03-11-2003 11:58 AM
No. Those were custom designed by Ryan Beckley at Kinetic Animation!
RUSSSR1 03-11-2003 12:17 PM
Cord,
Do you have a shot showing all of the boat?
Cord 03-11-2003 12:32 PM
1 Attachment(s)
Sure do!
RUSSSR1 03-11-2003 01:24 PM
Looks nice and clean did you do the int. to match
Cord 03-11-2003 02:07 PM
The colors work, but the layout doesn't match. I got the boat with the vinyl work already done. It's purple and white in a checkerboard pattern. The pattern is only in the seatbacks, so I felt that the hull design was pretty open.
Rick G 03-11-2003 03:20 PM
Thanks Guys, once again you guys came through for me. Jon pictures are being developed as we speak , and I will mail them out as soon as they are ready. By the way the boat came out better than I expected . White deck ( endura) Black hull sides (endura) White bottom ( VC Epoxy ). Now the re-assembly begins, putting it together without scratching it is going to be a challenge. Rick G.
