-   -   Hydraulic Steering Resevoir Bottle (https://www.offshoreonly.com/forums/general-q/45490-hydraulic-steering-resevoir-bottle.html)
RonS 03-16-2003 08:39 AM
What is the purpose for the Resevoir bottle on Hydraulic Steering,
I've noticed some boats with full hydraulic have them and others do not. Just wondering what the reasoning is for having the bottles.
Cord 03-16-2003 08:56 AM
On my boat, there wasn't enough capacity in the GM container. When the engine was running, it would suck it dry. When the engine was shut off, it would overflow. The reservior bottle adds just a little more capacity to the system.
Now, where is that spell check button?
audacity 03-16-2003 09:06 AM
it has A LOT to do with the geometry of the rams...as you trim up and down the the geomerty changes...some actuation ratios are more than others. there are some other issue involved as well but it's a no brainer to have one.
Payton 03-17-2003 06:46 AM
With some systems a single ram the resevior is an option, but on a dual ram it is required.
rbtnt 03-17-2003 09:18 PM
Does the bottle need to be mounted higher than the pump?
Cord 03-17-2003 10:06 PM
Yes. The line should also slope up to the bottle with out any dips. The low points will trap air in the line.
rbtnt 03-17-2003 10:10 PM
Thanks Cord.
dlbCheckmate 03-18-2003 08:44 AM
Overflow bottle is not needed on IMCO systems.
Cord 03-18-2003 08:51 AM
I needed to add one to my dual ram IMCO system. IMCO said that I didn't need it, but I got tired of running the pump dry only to fill the bilge.
dlbCheckmate 03-18-2003 08:57 AM
I also have a dual ram IMCO, full system. No problems (yet) 3 seasons, never know what a system will do ?
