-   -   teflon (https://www.offshoreonly.com/forums/general-q/45610-teflon.html)
carreraboat 03-17-2003 06:33 PM
teflon
will the good ol teflon in the tube be fine for my arp studs in my heads an d sending units?
Vinny P 03-17-2003 08:45 PM
Personally, I prefer brown aviation sealer for head bolts or studs. You need a good seal to keep out any water.
mcollinstn 03-17-2003 08:55 PM
teflon fine for sending units.
Audiofn 03-17-2003 09:04 PM
That is what I was told to use.
Jon
carreraboat 03-17-2003 09:36 PM
thanks for the responce guys i was told to use the blue thread lock not locktitie but then i was also told that plain teflon in a tube was fine do not want ant problems figure ask now before i stab her this weekend just wanted to know if anyone had bad experinces with teflon in the tube
thanks bo
cheitman 03-17-2003 10:18 PM
ARP THREAD SEALANT (teflon in a tube) will not work on head studs. I tried it on a SB stroker and could not get them to stop leaking. I had coolant seeping through every one. I asked my machine shop and they said to only use red locktite. I followed their recommendations and had no problems.
carreraboat 03-18-2003 07:56 AM
well so i pull my heads to replace sealnt can i reuse my head gaskets since the enine was never fired (head gaskets)
blown1500 03-18-2003 11:09 AM
You can pull the bolts one at a time and retorque each one. If you have a 502, the bojlt holes are blind and don't have to have any sealer. If you have holes that go into the water jacket, put a small amount of sealer on the underhead of the bolt and under the washer, if you have one. This will stop the water, but can cause rusted head bolts that can be murder to remove.
cheitman 03-19-2003 11:41 AM
Aslong as the motor has never been started you can reuse the gaskets.
