-   -   Maximum Hydraulic Pressures (https://www.offshoreonly.com/forums/general-q/45649-maximum-hydraulic-pressures.html)
blown formula 03-19-2003 03:33 PM
BAM & Alf of pressure. I guess thats why the steering hoses are so big. Both the Bravo trim & K-Plane pumps appear to be the same except for the reservoirs... one is plastic & one is a "tincan". The motors and pump assy seem just alike. Where is the pressure difference generated????
ALFSTER 03-19-2003 09:43 PM
The psi differance is controlled by the relief valve in the pump,and is set by cylinder size,and by thepsi the cylinder can safely work at.
