Yamaha drive conversion. to Merc ? >
Old 04-09-2003 | 08:22 AM
Ran-Dom 32's Avatar
Default Yamaha drive conversion. to Merc ?
does anyone know if you can convert a yamaha drive over to mercruiser?? has anyone done this?? It's a V6 application- can't find a used yamaha drive
Ran-Dom 32 is offline
Old 04-09-2003 | 10:05 AM
Biggus's Avatar
I swapped a 454/Yamaha package over to a Bravo last summer. The transom cut out had to be filled and recut for the Bravo. You will need a Merc coupler and bell housing and in this case I had to fabricate a pair of riser blocks for the engine mounts. You will also need a Merc shift cable bracket and change the cable ends. I had retained the Yamaha trim pump but had to change the Merc trim hoses to accept the metric fitting on the Yamaha pump. and I can`t remember exactly but we had to rewire the power trim system.
If I had to do it over again, I would have swapped the entire motor/drive package. You will find that most of the Yamaha motor accessories are really hard to come by. We waited 3 weeks for a sea pump.
Good luck,
Kurt
Biggus is offline
Old 04-09-2003 | 01:11 PM
Offshore Addiction
all you should have to do is pull the assy and swap it with the merc and bell assy,they passed a law years ago so that you dont have to refill and redrill the holes.......depending on the year swap......kinda like the outboards had to follow.......now merc and volvo will interchange etc,etc....I think yamaha followed suit the little time they were in business!only the old volvo and old omc have to be filled.......and merc even has an adapter plate now for the old volvo!most of the old omc seadrive boats are all scrapped!
Old 04-09-2003 | 02:34 PM
Biggus's Avatar
Are you calling me a liar? I did the job myself and the hole is not the same.
Biggus is offline
Old 04-10-2003 | 06:56 AM
Offshore Addiction
not at all,just that it should be double checked prior cosidering the possible year differences!
Old 04-13-2003 | 07:09 PM
I have the same problem with a shot yamaha drive on my dads19' Baja. Cant find a replacement and the boat isnt realy worth all that work to swtch over to a bravo If anyone ever comes across a yamaha drive give me a shout
otis311 is offline
djmadmatt
Classic Offshore
11
09-09-2008 02:48 PM
Btharbold
Drives and Lower Units
2
10-01-2007 07:23 PM
PIGPEN160
9
10-15-2006 08:30 AM
Magicfloat
1
07-11-2005 09:32 PM
ky4a
07-24-2003 06:00 AM
