-   -   502 carbed spark plugs (https://www.offshoreonly.com/forums/general-q/47409-502-carbed-spark-plugs.html)
Markus 09-16-2025 02:43 AM
If the Champions work well, keep them (or swap to the NGK equivalent if you consider Champion a lawnmower grade spark plug and don't want to be embarrassed if your friends stick their heads down the engine).
No need to experiment or reinvent the wheel.
SB 09-16-2025 04:27 AM
Looks like the mr43t’s and BR6FS ‘s cross reference each other. Therefore, if this is true, that should be a good plug for your engine. Gap is listed as .031”. Mercruiser usual spec ‘s .035” . So a quick check/adjust gap will be necessary.
