SSM III-IIIA
how can you tell the difference from the early III and the later IIIa's
thanks later |
IIIAs have the larger 26 spline prop shaft. Uses the same props as SSM V and VI. IIIs have the smaller 19 spline 1 3/8" shaft.
There are also some differences in the gimbals in the later IIIAs to make them stronger. Gary |
what year did the IIIa's start being produced?
later |
You can't tell by just the prop shaft, as it is possible to put the shaft from a big shaft #4 in a 3.
Take a look at the tilt pin hole, a 3 is 3/4, a 3A is 1". Of course it is possible to drill that out too. |
I guess I'll be more careful the next time I buy a IIIA from BAM:D
Marc, Will a 3a or 4 lower bolt right up to a #3?If not what do you need to do to convert them? Thank's, Ike.
Marc, also what drive oil do you recommend for my #3's? Ike.
Ike, no way to convert. A 4 upper is a different housing. A 3 and 3A have different vertical shafts in the lower.
We us the good old Merc HP gear lube. |
What are the differences between a 3a and a 5 other than length?
I've got 5's on a boatwith stellings boxes we're riggin and we're just now dialin in the props. Maybe a cupped prop will help us get on plane faster. Its a 38 that weighs 7800lbs. The drives are right below the transom, We're gonna try some cupped props next week to get that thing to plane off. |
| All times are GMT -5. The time now is 01:00 AM. |
