-   -   Octane for 525 sc's (https://www.offshoreonly.com/forums/general-q/47499-octane-525-scs.html)
CESSNA 04-14-2003 03:41 PM
Must have just been the nut behind the wheel ,or you really were lucky ,,,,maybe I got some bad gas ??
fstboater 04-14-2003 10:36 PM
I run 91 or 93 With 8.5 comp with alu heads no tstats with crossovers more cam 5psi boost 3500 to 6000 rpm to get it up cat with hi X! Ok so far keep the timing to 36 max and the temps low oil and water oil temp will come up at wot limit mine to around 250.
Back4More 04-15-2003 09:52 AM
say what?:confused:
