-   -   mercruiser 525 sc (https://www.offshoreonly.com/forums/general-q/47549-mercruiser-525-sc.html)
michaelsformula 04-11-2003 06:29 PM
mercruiser 525 sc
hello have a 99 525 sc what type of oil should I use in the blower? previous owner thought but was not sure about using 30 weight any input would be helpful thanks all !,Michael
cuda 04-11-2003 06:40 PM
I don't have an answer to your question, but where is the pic of Michael's Formula in the Formula section?:confused: :)
Griff 04-12-2003 01:05 AM
Use the Merc High Performance Gear lube--same stuff as the outdrive or an equivalent 80-90wt gear lube.
michaelsformula 04-13-2003 10:26 PM
mercruiser 525 sc
really 80-90 weight gear oil in the blower ?should i use a synthetic oil ?
HiPerf2000 04-14-2003 08:07 AM
80-90w is a good wieght to use....you are only lubbing the gears that are turning the 2 rotary shafts.
I always use synthetic in my blower. The merc hi-perf lube is synthetic. Use that or a Mobil 1 equivilent.
Back4More 04-14-2003 09:16 AM
Im with Griff...Thats what we used every season in our 525's
