-   -   JE Pistons compare to SRP (75F)Pistons (https://www.offshoreonly.com/forums/general-q/47595-je-pistons-compare-srp-75f-pistons.html)
502 Magnum 04-12-2003 04:48 PM
Got my 502 Gen 6 back from the workshop bored
0,30,the shop told me they have used JE pistons,
but inside the pistons it says SRP 75F.I need some
help here,what is the SRP 75F pistons? I`m not
familiar with that brand. Are they accepted for
use in a HP 500 EFI ? With a Procharger ? Thanks
502 Magnum
Tinkerer 04-12-2003 05:02 PM
SRP are an off the shelf piston built by JE. The JE's are usually custom built for your app. This is just what I have been told. They are cheaper to buy than the JE's.
blown1500 04-12-2003 05:04 PM
SRP is the "economy" branch of JE. They are a very good piston, but are mass produced instead of on the JE line and are not quite as good material. They probably will live in your motor if you don't make too much boost. Price is considerably less than JE so I would see what I was charged and if you said "JE pistons", I would need to have a talk.
502 Magnum 04-12-2003 05:38 PM
JE pistons compare to SRP (75F) Pistons
Thanks for reply and the suport I feel here Guys,
blown1500, I think you`r right ,and if I`v told you
the price this well accepted workshop Gent in
Ft.Lauderdale took to do my shortblock,
I`m shure you will cry out . Ok,I`ll give the man
a call before I `ll go any further here.
502 Magnum
Scarab28 04-12-2003 07:54 PM
SRP - Sporstsman Racing Piston
bobby daniels 04-13-2003 01:55 PM
the machining and material is not as good as J&E proper pistons and are alot cheaper ,,,,go with J&E :D :D
502 Magnum 04-13-2003 04:47 PM
blown 1500
Just got the Manley valve set you sendt to
my buddy in Ft.Laud.d. came with Fedex here
yesturday,great,thanks :D :D
