-   -   DYNO Results (https://www.offshoreonly.com/forums/general-q/48203-dyno-results.html)
JimV 04-21-2003 08:09 AM
DYNO Results
I finally dynoed my motor at Tom Earharts. 565cid std. deck, hand ported 325cc Pro one heads, tunnel ram, fuel injected, hydraulic roller. Here are the results.
..rpm............Corrected torque.............CHP
1500.....................516...................... ...147
2000.....................569...................... ...217
2500.....................591...................... ...281
3000.....................601...................... ...344
3500.....................655...................... ...437
4000.....................657...................... ...501
4500.....................714...................... ...612
5000.....................720...................... ...685
5500.....................687...................... ...720
6000.....................655...................... ...748
rjcardinal 04-21-2003 08:31 AM
Wow! Very impressive. How radical is this motor? What is the compression ratio? What are the cam specs? Whats the expected lifespan on the valvetrain?
I need details!
Ron
WETTE VETTE 04-21-2003 09:43 AM
Hey Jim, How much compression is that motor?
JimV 04-21-2003 10:30 AM
The motor is 10.5:1, runs on 92 octane. It likes 33 degrees of timing. We tried different timing, up to 36 (with race gas) and didn't make anymore power. The cam is our grind, .648 lift (same cam as our 540's) and is very user friendly at the dock with a carb or efi. We have been running this valve train set up with great success, lifter/ valve spring change recommended at 300 hrs. The power fell off after 6000 which is OK for a pleasure motor.
WETTE VETTE 04-21-2003 11:03 AM
Hmm. So what do you think? Same heads on a 565 with 12.5:1 compression with a single dominator on a Dart intake with a solid roller should be 800 plus HP. Ya think or not?
bobby daniels 04-21-2003 11:38 AM
looks good Jim , :D :D
JimV 04-21-2003 05:16 PM
WETTE VETTE
I'll bet it would be close
bobby daniels
thanks!
DanB 04-21-2003 05:44 PM
Jim
Sounds like a pretty stout motor
You still coming down in May? We race Marathon May 16th
Dan
JimV 04-21-2003 06:48 PM
Dan
I'm going to try, 50/50 chance right now. I have a lot of work to get done. I will let you know either way.
fred 04-21-2003 08:26 PM
Jim, those torque numbers ought to hold you back in the seat for a while!!!!....WoW.....Nice Job,....Fred
dyno 04-22-2003 02:20 PM
Looks great Jim! The Fountain should be ready to rock soon right?
dlbCheckmate 04-22-2003 02:51 PM
Wow, impressive numbers. I know where my next motor will come from !
JimV 04-22-2003 03:15 PM
Dyno
Hope to splash it next week
dlb thanks!
Crazyhorse 04-24-2003 11:38 AM
Good job Jim. Hi DanB.
cobra marty 04-24-2003 01:37 PM
1.32HP/CID for N/A pump gas motor is great!
