Props for Fountain 35
I have a 2000 Fountain 35 Lightning Classic (single step) with Whipple Superchargers on HP 500EFI Engines. Does anyone else have this setup ? What propellers are you running ?
What gears are you running what cam,--is your X deminson std. or higher ??:confused:
1.5 gears, standard HP 500 EFI cam & the X dimension is std.
32 or 30 bravo 1 seems to do good with that set up did you get the ecu ,,,,rpm limiter changed ??/?if not raise it as you don't want to hit it as it cuts fuel to stop RPM ,,,bad deal for blower
| All times are GMT -5. The time now is 06:51 PM. |
