-   -   Painting polished stainless? (https://www.offshoreonly.com/forums/general-q/48841-painting-polished-stainless.html)
THRILLSEEKER 04-30-2003 07:13 AM
Is there any certain precaution to painting polished stainless steel? special primer, or paint? Or does it cover just like any other steel?
later 04-30-2003 07:54 AM
i would sand it good use a etching primer then a regular primer then paint.
later
ren3 04-30-2003 08:53 AM
Make sure that you unpolish it with 80-120 grit. Degrease with acetone. Prime it with an epoxy primer and paint with a good two part urethane such as Interthane Plus from Interlux. Easy to apply and readily available.
THRILLSEEKER 04-30-2003 10:30 AM
Thanks for the help fellas, I just etched it real good with about 130psi. and a pot full of silica sand:crazy:
formula31 04-30-2003 02:00 PM
That will work good, use a primer too.
dougB 04-30-2003 09:23 PM
HOUSTON PROP/PAINTING S.S. PROP
it will never stay on. A omc painted stainless prop is teflon coated which in time still comes off on the tips of the blades.You could have the prop power coated and the insall a new hub insert if its rubber. Darin oh screen name still coming up dougb?????????????/
KCHOTBOAT 05-01-2003 08:34 AM
I had all my stainless steel powder coated several years ago and still looks great.
