-   -   Broken Skeg (https://www.offshoreonly.com/forums/general-q/49114-broken-skeg.html)
epeek 05-03-2003 04:39 PM
Broken Skeg
Help,just got done repairing my bravo hinge pin,helicoil
worked fine. My wife was naggin to move boat from
driveway, I forgot drives were down and broke chunk
out off both skegs. Is the skeg really important or
can I just grind them clean? Are the stainless bolt
on Skegs any good?
fountain10 05-03-2003 04:52 PM
if it is a small piece missing - I wouldn't be too concerened. If is a big chunk you can get it welded back on.
WILDTHING TAZ 05-03-2003 05:00 PM
yes you need skegs to control boat & steering.too much missing can cause spin outs and out of control handling. a small chunk gone probably won't hurt.if you lost more than 1/2 you need to fix them.you can have a welding shop weld them back.or if to much is gone.mercury sells full skags that you cut yours off and weld a new one on. RB
Quest for Speed 05-03-2003 06:17 PM
If you only broke out a "chunk" of each skeg you likely fix it with JB Weld. I just fixed one of mine that had a piece about the size of half of a silver dollar and you can not tell it has been repaired. I took a piece of duct tape and taped it to one side of the drive, filled the hole with JB Weld and folded the other end of the tape around the other side of the drive to hold the JB Weld in place while it dried. Pulled the tape of the next day and sanded it flush with the rest of the skeg and painted it. You can buy the Quicksilver drive paint that Merc uses at any large marine store like West Marine. I hope that helps.:p
epeek 05-03-2003 07:51 PM
I took a chunk about 2" by 1" and another about 1" by 1"
out of 1 drive and the skeg is slightly bent, a small chuck
out of the other drive. IT looks pretty mangled. Thats why
I am considering the stainless bolts ons. Has anybody
used these?
WILDTHING TAZ 05-03-2003 08:10 PM
A good alum. welder can fix it right on trailer sand it & paint it for about 30.00-40.00 each.then tell your wife what shee owes you.:D
SkiDoc 05-04-2003 06:03 AM
My wife forgot to put the drive up last year....what a bad sound. If you really don't want to fix the problem, I ran all last year with a 2" chunk off the trailing edge. Just painted it. I am going about 80 and I could not tell a difference. My solution....I bought an Imco Exteme SC told the wife it was broken and it had to be fixed!
Eric
HOUSTONPROP 05-04-2003 08:54 AM
skeg guard
used these?
they are neat but if you hit something hard enough ,it will break where the stainless bolt on is attached../something to think about ,the strongest is the original skeg ,fix the little chunks that are missing and you will be in good shape.
Darin;)
TROUBLE MAKER 05-04-2003 10:55 AM
I've got one of those Skeg Guards on order now, because I busted a big moon shaped piece off it last season. I figure if I have a similar incident this season with the skeg guard on there it will just brake the whole thing off, then I can get a new one welded on...or get a new drive...
:p :p
otis311 05-04-2003 08:16 PM
Im suprized thats all you ripped off if your WIFE WAS NAGGING !!
What next Rick, Get That thing in the water will ya. I ran mine after the funeral with Jimbo, then ran it this weekend. No problems as of yet. It did take 250 gal of fuel to bring her just over 3/4 though !!
She is going to Vince's for the week to put the liquid DJ booth in her. Cant wait to her it. Talk to you this week
epeek 05-04-2003 08:38 PM
Hey Robby, I heard that cig was sittin at Mack The Knifes,
You gettin some paint work? I busted my ass all weekend
on my boat, I think I got 150 hrs in it. Im 99% done. I
should be in the water this weekend. Im gonna put on
the skeg gaurds. I dont want to go thru welding them
now. If the skeg gaurds get broken then Ill weld them
or buy new housings.
otis311 05-05-2003 05:16 PM
Mac had her for 2 days doing some touch up work and redoing the Cigarette Top Gun on the sides and painting the name on the back. We had it out all weekend and all went good, ran good with no problems what so ever. Now the boat is at Original Soundz for the week. My brother and Vince spent this afternoon planning this System. Its gonna sound unbeleivable. Ill be back in the water for Sat. then back out for a week of waxing and buffing, getting ready for the Queens boat race weekend.
patrick22309 05-05-2003 05:59 PM
Skeg Guard is bad!!!!! Hit a rock last summer and broke the entire skeg off. The welding shop said I was lucky I didn't oval shape the drive housing becaue that usually happens also. There was other damage, can you say new vertical drive shaft and prop shaft.
