engine serial numbers
Are the Mercruiser engine serial numbers on the valve covers supposed to be the same as the numbers stamped on the front of the block on the deck? Motors are '99 502's and these 2 numbers do not match.
Thanks |
no. the numbers on the deck are gm. only merc hp engines actually stamp the block. the regular merc engines have a riveted plate on the rear stbd side of the block above the starter. merc dealers have a list to match gm numbers to merc models
THANKS! I was beginning to wonder if my motors were the originals. That explains why the stamped number has extra letters on the ends does not even come close to the Merc numbering system.
My last boat had a HP465 and the stamped number matched the Merc number. That was my reasoning for asking. |
| All times are GMT -5. The time now is 01:03 PM. |
