-   -   cam advice (https://www.offshoreonly.com/forums/general-q/50197-cam-advice.html)
delsol 05-16-2003 06:09 PM
cam advice
I'm hoping to get some feedback on a cam selection for the motors i just ordered;
Dart big M Tall deck
Callies 4.5" crank
Crower rods 6.7"
JE pistons 4.560" Speed pro total seal file fit rings with a 1.24 compression height .010" in the hole should be 9.75:1 CR
I think I'm going to use my rect GM heads with a mild prot and bowl work for now, then replace with AFR's next year
Dart/ edelbrock victor intake
IMCO powerflow exhaust
I'll run my 850 Holley until i change heads, then replace with a 1050cfm Holley 4150
Cam will be a Hydraulic roller-- what duration should i be running to be a good all around cam, want to run no more than 5300 rpm, preferably 5100 rpm. I'm really looking for low/mid-range torque
I've been told to go around 240-246 intake, and 244- 248 exhaust at 50, with a 112 lobe seperation.
What does everyone think???
Thanx, Dave
KAAMA 05-16-2003 10:18 PM
I have one (1) Ultradyne hydraulic roller 244*/244* on 112* lobes with dyno time only for sale. I thought it was a little too large for my 540's , but would probably work fine in your 572's.
Dave F 05-17-2003 09:20 AM
What do you think about Crane's 244/256 114 .632/.632?
#139651 It has 22* overlap.
DAVE
delsol 05-20-2003 09:51 AM
I was trying to use the same cams with my gm rect port heads as i will use with the AFR's-- but I'm being told that i have to have way more of a spread between int and exh with the gm's.
DaveF--- maybe the 244/256 would be close to what i need for the gm's, and then change the cam when i change the heads
Might bring it a little more conservative --242/250 since the heads have a little bowl and port work.
KAAMA 05-20-2003 10:24 AM
The cam I mentioned made 699hp @5700rpm in my 540's with Dart Pro-1 fully ported aluminum heads------If you guys know of anyone who's interested in it. :)
delsol 05-20-2003 02:12 PM
Kaama --I will keep it in mind if anyone is looking. with the heads you were running I think that would be a great choice, but with the stock gm i don't think the exhaust will open enough.
delsol 06-03-2003 05:23 PM
ttt----588's
I've decided to go ahead with the AFR heads right away, had to change the rods to 6.535" crowers as there were no oliver 6.7" available in my time frame.
This means that I will be using a 1050 dominator carb on a dart intake port matched to the 335 cc AFR aluminum heads.
Compression is at 9.72:1 now. Is AFR's recommendation of even intake and exhaust numbers sound reasonable-- they feel that with their better exhust port that it doesn't need to be any bigger than the intake lift. Does anyone have this experience??
As always any insight is much appreciated, Thanx, Dave
bobby daniels 06-03-2003 08:43 PM
your right or they are ,,the AFR's are great I've run alot of them and sell some .
go ahead and get hard anodized heads and T&D shafts while your at it :D :D
delsol 06-03-2003 08:53 PM
Thanx for responding Bobby
These are going to be hard anodized, I figured why not get a little corrosion protection:D
What are the t&D shafts though?? rocker arm shafts??
So you think that cam would be alright for this application??
delsol 06-04-2003 07:22 PM
ttt
delsol 06-18-2003 12:24 PM
This is the cam that got ordered for these engines, is the 114 lobe seperation too much or should it be 112? and as far as the lifts @ .050 is there more spread than whats needed for the AFR 335 heads -- and what influence would it make? The overall lift looks a little low too? or am I making too much out of it??
Here are the cam specs....
Duration @ .050 240/247
Lobe sep. 114 Int. centerline 110
Lift .618/.629
Please any feedback will be greatly appreciated!!!!!
bobby daniels 06-18-2003 12:30 PM
Cam looks fine the spread is not to bad ..
The AFR heads are unreal :D :D
Milord 06-18-2003 01:22 PM
Are they done yet Dave? :)
delsol 06-18-2003 03:56 PM
Not yet:mad: :(
delsol 07-10-2003 07:28 PM
Lift .618/.629
This cam is now in the engines, AFR has sent the heads --but possibly with the wrong springs for a hydraulic roller cam --above-- is 250 lbs seat pressure too much ?? The builder has changed 1 set to 125 lbs closed and about 320 lbs fully open, does this sound right???
The last thing I want to do is break/float a valve --max rpm will be 5200-5300.
Any insight would be great --- we want to dyno on saturday!!
Cord 07-10-2003 09:21 PM
I'm thinking that your engine would gain from a better exhaust system. You need something that is more like a true header with some good long primaries.
delsol 07-10-2003 09:26 PM
Cord you're probably right! It sucks that i just bought those last year for my 461's--- i didn't think i was going to be going into this kinda ci right away. They'll have to work for now -- I just blew the wad on the motors.
I just did a bunch of searching and found that the 130# seat pressure should be alright from what I've read.
RLW 07-11-2003 10:11 PM
I believe the 1050 Holley is a 4500, not a 4150.
Do they make a 1050 cfm 4150?
