Bravo Coupler Torque
Any body got the torqe spec for the drive coupler and bell housing.
coupler to flywheel is 35 ft/lbs,,,, flywheel to crank is 75 lt/lbs,,,, bellhousing is 30 ft/lbs
Thanks obnoxus,
thats what i did. Actually used arp bolts on the flywheel and they spec 75lbs if using there lube, 115lbs in you use 30wt oil. |
Use a dab of locktite (blue) on the coupler bolts.
BT :cool: |
| All times are GMT -5. The time now is 07:21 PM. |
