-   -   Holley Carbs (https://www.offshoreonly.com/forums/general-q/50680-holley-carbs.html)
BAD-HABIT 05-23-2003 06:43 AM
Holley Carbs
Am looking at getting a Holley. Because of money Ive spent on the boat in the last year Im looking to go used...Any body got a 600-750 holley for sale. I need something in good condition and pref with vaccum secondaries and an electric choke. GOT TO BE MARINE...Any thoughts on going with a holley. How hard are they to dial in?
BH
Mr. Demeanor 05-23-2003 09:03 AM
I have a marine Holley 750 with vacume secondaries off a 92 OMC. Its completely rebuilt (didnt need it but I had it off so I did it) and has the quick change secondary spring kit and an assortment of springs. I have enough jets and power valves that I could set it up however you want. The carb looks like brand new but is painted gray. I was looking for $250. I'll be gone most of day today but let me know if your interested.
I hope this resolves your ongoing problems.
blown1500 05-23-2003 10:41 AM
What do you have now and why do you want to change???
BAD-HABIT 05-23-2003 05:40 PM
I am chasing multiple problems with my motor.....Have replaced/rebuilt just about everything on the damn thing....Im running a 600cfm Edelbrock which I can't seem to get to set right....Rich as hell at idle,Lean on the top end...Bought a new fuel pump pushing 6-1/2 lbs and still no fix...Im thinking the thing must have a crack somewhere hidden (see my past posts). Come to find out Edelbrock says that it will only hold 5.5 lbs of pressure!! Of course I found this out AFTER I changed the fuel pump....Got a VERY good deal on a 4010 holley with very low hours on it so Im gonna hope that it is the source of some/all of my problems....
BH
Mr. Demeanor 05-23-2003 08:45 PM
Best of luck to you. Your thread has been interesting to read.
When you hook up the Holley, do not use the chrome dual inlet lines. I did and had problems. They were Holleys lines purchased from Jegs. In their infinite wisdom, they chrome the inside of the line back a bit from the flare. when you tighten them down a few times during the dialing in process, the chrome flakes off and fills your float bowl screens. Get the braided lines.
