-   -   Intake Crossover (https://www.offshoreonly.com/forums/general-q/50767-intake-crossover.html)
seeeya 05-24-2003 06:18 AM
Intake Crossover
I am rebuilding my sbc and after reading Dennis Moores book I am considering using an intake gasket that would block off the exhaust crossover. How much of an effect on cold starts will this have? How much performance will I gain? My 350 has been bored to .30 over, balanced & blueprinted, 441 heads 202 & 160 valves
polished, might be ported? comp cam 270H, Performer intake, Edelbrock 600 marine carb, Msd ignition box. Stock exhaust.
I boat in Northern Indiana & normally boat in 70 to 90 degree weather.
The sbc goes in a 1986 22' sea ray pachanga.
Thank You
Scott
bobby daniels 05-24-2003 11:50 AM
use a dual pattern cam larger than a 270 /and blocking the exhaust is not a big help on the boat :D :D :D
seeeya 05-24-2003 01:10 PM
Thank You Bobby
But I'm confused, should I use a different cam?
And not block the exhaust crossover?
Scott
bobby daniels 05-24-2003 03:39 PM
yes sir seeya use one of thier dual pattern cams with a larger exhaust profile and slightly larger intake profile the 270 is on the small side ..
Also in a boat the cross over is 50/50 leave it or take it out I've never seen any improvement or loss due to it..
hope this helps you fly
seeeya 05-24-2003 05:09 PM
Thanks for the reply Bobby.
I'll call comp cams and forget the crossover.
