-   -   Bennitt Ditgital Tab Indicators (https://www.offshoreonly.com/forums/general-q/50871-bennitt-ditgital-tab-indicators.html)
Ran-Dom 32 05-26-2003 09:24 AM
Got one that stays completely lit (ind. tab fully down) anyone know if fixable?? indicator is faulty - tab still works fine
Milord 05-26-2003 10:13 AM
You can get instructions from Bennett's site on how to reset the computer. It might fix your problem.
Indy 05-26-2003 03:42 PM
Bennett is about the most customer service oriented company I've ever dealt with. One call to them will correct your problem. Good folks.
32storm 05-26-2003 06:51 PM
I had a set of those on my Formula. Continuous problems. Most unreliable pieces of s**t . Bennett was great about sending replacement parts, but the system was not rugged enough to handle the combination of speed and rough water. The Formula would handle it great, but next thing I knew the Bennett indicators were f###ed again. Is it fixable? Absolutely. You will probably end up, replacing either the indicator in the trim cylinder, which requires re-wiring back to CPU, or the CPU itself. I went thru (2)CPU's, and at least a pair of indicators. In discussions with Bennett tech's, they indicated that the system was more oriented to cruisers, and probably never even tested at speeds over 60 MPH. I couldn't pin them down, as to cause. I can only speculate that it was the shock of re-entry that was wrecking havoc.The Bennett tabs are a great product and the company is great about sending parts, but you can't fix a bad design. You may want to consider looking at Gaffrig's mechanical systems for the Bennetts.
formula31 05-26-2003 08:22 PM
I have to agree with 32storm. Mine havent been very reliable either. I continually have the flashing indicator thing and have to recalibrate. I have even run a dedicated shielded power line right from the batteries. Didnt help. Im gonna try a big capacitor to filter the line next.
Ran-Dom 32 05-27-2003 02:27 PM
Well you guys are right about customer service at Bennett -very good - Tom from Bennett told me what to check & turns out I need a new Indicator - will warranty no problem - even though boat is way out of warranty - can't say that about to many company's
