-   -   steering fluid leak (https://www.offshoreonly.com/forums/general-q/50924-steering-fluid-leak.html)
mg503 05-26-2003 10:26 PM
steering fluid leak
Picked the boat out of storage and the power steering pump was dry ,found a puddle in the rear of the boat near the controll valve and booster /re-filled the pump and ran the boat /going thru the whole range of motion on the wheel with nothing spraying out question is if i take it out on the water do i run a safety risk ? or is the worst thing i would end up with armstong steering? the boat's a 89 baja sport 190 motor is new and the steering system looks the same
