-   -   alpha gear ratio ? (https://www.offshoreonly.com/forums/general-q/51285-alpha-gear-ratio.html)
Raven 05-31-2003 06:05 PM
alpha gear ratio ?
if I have a 1.84 drive and use the lower section of a 1.98 drive is my ratio still 1.84 ? I heard the gearing is in the top and if i use the lower it will be the same as my 1.84 is this true?:confused:
Raven 06-01-2003 10:31 AM
somone on here must know the answer to this ???
Raven 06-01-2003 02:35 PM
no one??????
sterndrivespec 06-02-2003 07:12 AM
the gear ratio in an alpha drive is changed in the upper.the lowers are all the same
