-   -   burning clutches? (https://www.offshoreonly.com/forums/general-q/51428-burning-clutches.html)
yesrej 06-02-2003 03:54 PM
burning clutches?
i have a omc king cobra outdrive. i was having shifting problems with it. i now know why i was having shifting problems. i have a burned out clutch. now my problem is, i just replaced the clutch last year at the end of the season. the clutch only has about ten hours on it. why am i burning up clutches. the outdrive is a 1990 with a cone clutch. if anyone has any clue of why i burned up this clutch so fast please let me know so i can put this boat in the water.
mcollinstn 06-02-2003 11:58 PM
sticky or misadjusted shift cable or linkage?
using cheap gear lube?
didn't get all the nast flushed out of the gearcase from the first clutch failure?
swood5991 08-30-2005 11:03 AM
Re: burning clutches?
I heard that with the OMC outdrive, if you do not use 100% synthetic gear oil, you may create a problem.
