-   -   blown 520 idea...need roller cam advice (https://www.offshoreonly.com/forums/general-q/51697-blown-520-idea-need-roller-cam-advice.html)
timucin 06-05-2003 06:34 PM
which roller cam #?
planning to install a 8-71 blower
cr:9 to 1
everything forged inside the engine.
thnx
bobby daniels 06-05-2003 07:10 PM
WHAT TYPE ???? SOLID HYD ,,HEADS? COMPRESSION :D :D
timucin 06-05-2003 08:33 PM
compression : 9 to 1
solid
gm hi-perf rect port heads
bobby daniels 06-06-2003 03:49 PM
Something maybe 10* more on the exhaust than intake and 680 lift ,,,248*intake /@257* @50 lift 112 * lobes this would be a killer blower cam and still be very easy to drive around and turn
6200+ and be a torque monster
,,we have some ground for use and look at comp and crane or get Isky to grind it for you :D :D
timucin 06-06-2003 06:02 PM
thnx Bobbby but i coulndt fian a cam with your specs.where can i get them part#?
bobby daniels 06-06-2003 07:06 PM
I have either Isky or Ultradyne grind it but you can do that or just find one close :D
timucin 06-06-2003 07:50 PM
bobby : pls check your private message
