-   -   Engine size vs reversion. (https://www.offshoreonly.com/forums/general-q/51901-engine-size-vs-reversion.html)
WETTE VETTE 06-08-2003 07:23 PM
Is there a relationship? Example my 498" BBC is running a 272/280 duration @ .050" cam on a 112+4 installation. My exhaust pipes exit completely underwater which makes it very quiet which I personally like especially with BS noise laws. Anyway with my 498 there is no problem with reversion with the exhaust I am currently running. Would the same or basically the same cam be reversion free in say a 540" or 572" using the same exhaust? Does the larger motor pull more back on overlap and does the extra flow leaving the exhaust basically keep the reversion away? I hope I am stating what I am thinking clearly.:rolleyes:
Thanks,
Craig
WETTE VETTE 06-09-2003 12:45 PM
Dang, no answers! Well with a larger motor the vacuum signal to the carb will be better than a smaller motor running the same cam. Does this also mean there is more vacuum during overlap to pull back the exhaust, or will the added exhaust flow / velocity offset the increased "exhaust vacuum"?? I guess it is one of those things you won't know until you try it out.
bobby daniels 06-09-2003 03:07 PM
NO SIR VETTE WITH THE SAME SIZE CAM IT WOULD BE LESS THE LARGER THE ENGINE ,sorry about caps it was stuck !!:D
WETTE VETTE 06-09-2003 03:25 PM
Bobby,
That is good to know and kinda what I thought. I try thinking things through and sometimes come up with some off the wall thoughts about what may happen. Thanks for the response.
bobby daniels 06-09-2003 04:02 PM
Yes I do the same thing ,,brain fade at my age !!!:D :D
MACDAD260 06-10-2003 04:45 AM
On your cam specs; Did you mean that the cam is 272/280 minus 50* or 272/280 @ 50*? If it is the latter then that is a LOT of duration! I didn't know you could run a cam with those specs in a boat WITHOUT getting reversion. Just curious.
BROWNIE 06-10-2003 09:54 AM
I agree that those duration #'s are astounding. This is an important topic. Could you double-check them?
WETTE VETTE 06-10-2003 11:43 AM
The duration I mentioned is not a misprint. The specs are @ .050" lift and I currently do not have any reversion problems with the 498" motor and and the CMI exhaust I am currently running. They exit about 6" below the water so they are real quiet at idle and at the same time because of the drop there is a lot of dry pipe which keeps the reveresion at bay. The reason I ask about the larger motor is because my 498" is running 13.2:1 compression and $3.00 gas. If I go to a 572 or 598 I can run 10:1 comp and use basically the same cam on pump gas and make close to the same amount of HP as the 498 is now running 110 octane.
kingsize 06-10-2003 06:16 PM
Just curious....if your gross cam lift duration @ .050 is 272/280 what is your running duration?
WETTE VETTE 06-10-2003 06:30 PM
Duration @ .020" lift is 308/316, and the duration @ .050" lift is 272/280. Advertised duration isn't even listed on the cam card. Lift is .714" and valve lash is .024" hot.
