-   -   Deep sounder (https://www.offshoreonly.com/forums/general-q/52280-deep-sounder.html)
JS232 06-13-2003 08:21 AM
Deep sounder
Transducer installed under engine... Is not accurate (only in the deep). Otherwise, bad readings, flashing numbers 90% of the times. Was installed by dealer, he offers installing a new transducer outside on the bottom transom... (62 MPH boat)
Any suggestions ?
Elite Marine 06-14-2003 06:37 PM
Was the hull hole sawed out to the outer skin? DId they put mineral oil in the cavity?
I wouldn't go external.
convincor 06-14-2003 09:38 PM
Some have sensitivity adjustment on the back of the gauge.
My "UNIDEN" did. Once adjusted, alway's had good reading.
That was in a CHECKMATE with a balsa core hull. I didn't get down to the outer skin and it worked fine.
