Valve Covers for 1071 blowers
Who is running a 1071 supercharger on a standard deck big block, and what valve covers are you using? I removed a B&M 250 blower and replaced it with a littlefield 1071, now my 2 piece valve covers hit the intake. The motor has a stud girdle so the valve covers have to be tall enough to clear.
I'd go with that friend of yours BUDAH he had a good idea and can help you quick even on a velocity ,,LMAO:D :D :D :D
I run a tall deck now with BDS intake manifold and Teague's valve covers. Run a stud girdle under them. I had the same set up on a std deck block with no problems.
First, you need a good blower and intake. Then you do have to grind the valve cover adaptors to clear the intake runners. Your intake and blower are great and so are the covers, just call me or BUDAH.:D :D :D
OK guys I know that other people out there are running standard deck motors with a 10/71 Blower. My intake is a Littlefield and from what I can tell there is no way that you can get a set of valve covers on the motor with out cutting the intake or the valve covers. Someone has to have an idea.:confused:
| All times are GMT -5. The time now is 08:20 PM. |
