-   -   Still leakin oil!!! (https://www.offshoreonly.com/forums/general-q/52368-still-leakin-oil.html)
dyno 06-14-2003 08:06 PM
Still leakin oil!!!
dang this thing is driving me crazy! I've had the motor out, fixed what I thought was the problem but it still leaks, about a quart in a hour. I've got it narrowed down to the area of the remote attaching to the block. Its a real pain to get to twins and all. anyone know if I can pressurize the system to aid in finding the leak. I pulled the distributer out and ran the oil pump with a drill the first time I was looking for it and thats how I found what I thought was my problem not!. I had a new line made last season and wonder if its a bad fitting. if I took the line off at the remote filter and put say 50 lbs of air to it would that work????Help!!
MACDAD260 06-14-2003 09:11 PM
Air pressure may work. Air is cheap. It's worth a try. If that does not work I would put some dye in the oil and check for leaks with a black light. If you don't know anyone with a black light and some dye I can hook you up. Give me a call. 318-1569. Doug
KAAMA 06-14-2003 09:39 PM
I have a small hand held black light if you need it Don, but you'll need to call me on my cell and not rely on this message board to get a hold of me because I am right in the middle of moving into my new home.
Mark
blue thunder 06-15-2003 08:09 AM
I feel your pain dyno. I've been chasing leaks for several years now. Had the engines out 3 or 4 times already and still have an oily bilge. Got it down to one engine only now. This is the one I didn't change the rear main seal in, so it is either that or the crossdrill plugs you guys have been talking about.
In addition to using air to pressurize the oil system, think about pressurizing the crankcase as well, with 10psi or so. Those two test should show evey possible weak point. My biggest problem was found with the crankcase pressurization method. Oil was leaking at the two drilled and tapped holes near the rear main that do not get filled when using a cast aluminum pan. They can really puke oil.
Man I hate an oily bilge!!!!!!! :hothead: :hothead:
BT :cool:
dyno 06-15-2003 09:01 AM
Thanks Guys!
paradigm shift 06-15-2003 09:25 AM
As for where it is leaking I could not say. You might consider rigging up a test run stand so you can run the motor out of the boat. Really is not that hard to do. Probably no worse than pulling and reinstalling a motor several times trying to find an oil leak. :hothead: Just a thought.
The oil pump primer drive is probably your best bet to try and locate it. As bad as you are leaking I would think you could clean it up realy good and use the primer or run it for a short time. Those little inspection mirrors on a wand may also help getting to those tight spots. I have also used a digital camera with auto focus and just hold it under the motor and snap several pictures. If there is room.
Mr. Demeanor 06-15-2003 11:26 AM
Baby powder can help as well but if you leaking that much it'll sick everywhere.
tssteph 06-16-2003 08:23 AM
Not sure what motors you have but a common area is in the front of the block where a stock fuel pump would bolt on, there is a bolt hole there that goes into the fuel pump push rod passage. This bolt hole looks like a blind hole but it isn't. GM used this to hold the push rod in place during assembly then the bolt would get switched for a shorter one.
Just a thought, I have fixed several oil leaks that people couldn't find by putting a bolt back in the hole...
Brian
dyno 06-16-2003 08:36 AM
MackDad hooked me up with some dye and I got a battery powered black light from the maint. guys at work I should be able to find it soon!!!
Cord 06-16-2003 09:13 AM
Be sure to save some for the next LOTO trip. That stuff would make for some really cool mixed drinks!
dyno 06-16-2003 09:16 AM
Het Cord ! whats up? the cat ready? I'm still waiting for a ride!!!
