-   -   Hole in thermostat?? (https://www.offshoreonly.com/forums/general-q/52445-hole-thermostat.html)
THRILLSEEKER 06-16-2003 09:50 AM
I just replaced t-stats on my engines and I noticed that there was a hole (looked like it was drilled) on the "plate" part of the t-stat, there is no hole on the new ones that I bought.:confused:
I have heard of drilling holes in t-stats before but I am not sure of the purpose or in I need to drill my new ones?
JUSTONCE 06-16-2003 10:08 AM
It allows for some flow even before the t- stat opens. Not a bad Idea esp. if you make alot of short runs.
Wally 06-16-2003 10:28 AM
also helps get rid of steam pockets if youve had overheating problems in the past
28SS 06-16-2003 11:15 AM
As Wally said steam pockects . I had replaced one of mine and did not notice hole I had eratic temp all the time until I figured that out.
THRILLSEEKER 06-16-2003 11:46 AM
Well, sounds like I have a few holes to drill:p
Thanks guys:cool:
Cord 06-16-2003 12:52 PM
Just hold on tight and go slowly. Those edges are really sharp and if that bit grabs you could be hurting.
