-   -   replacing floor in a cat. (https://www.offshoreonly.com/forums/general-q/52474-replacing-floor-cat.html)
KCHOTBOAT 06-16-2003 04:02 PM
Found out the floor in my HTM has some real soft areas under the back seat. The boat does not drain very well so I am thinking about replace the wood floor, add layers fiberglass and then paint it. Looking for ideas, advice and and info I may need.
liquid lounge 06-16-2003 04:13 PM
I've never done it, but I think somthing like King Starboard Lite would be pretty trick....might need two layers depending on how well its supported underneath......would be lightweight and never rot...could go over it with Pirrelli flooring or carpet....just some ideas:eureka:
KCHOTBOAT 06-16-2003 04:28 PM
What is King Starboard Lite? The plan at first was Pirrelli flooring and still may finish it off with it.
puder 06-16-2003 05:32 PM
it will proably need opt be faired out. Fiberglass over plywood never seems to be as smooth a finish and one would think.
Audiofn 06-16-2003 10:18 PM
I would use High density Foam.
KCHOTBOAT 06-16-2003 11:32 PM
For the floor with fiberglass on top?
puder 06-17-2003 01:01 AM
i did soem foam glass stuff make sur eyou use epoxy resin with it. The other crap melts it!!!
onc eyou biuld up several layers of glass on the foam it become pretty damn durable
Audiofn 06-17-2003 07:00 AM
Yes with glass on top, and the bottom. We did that in a buddy's Hydrostream and it was ROCK SOLID. I believe if memory serves we used lighter foam but made it thicker to compensate. We I believe used 1" 8 pound density. Then we put 12 pound density plugs in any place we were going to have to bolt anything to the floor. It worked out great. There are lots of options. However consider this. Plywood if properly installed should last you more then 20 or 30 years so do you really want to get into ussing the exotic stuff? It can get real expensive.
As far as the foam I use you can use polyester resin with it no problem.
Jon
liquid lounge 06-17-2003 08:58 AM
The King Starboard Lite is like a sandwiched high density foam, with a hard poly exterior on both sides....on my boat they used it for all the seat bases and backing plates....pretty stiff, but everything would have to be through bolted...what do you think Audio...have you seen the stuff? KC, they may have some Starboard Lite [or a knock-off] at Fantastik Plastics on Gillum. Do a web search on King Starboard..they have a web site. If you want you can see it on my boat as I keep it in the warehouse where I work in Lenexa. Take care
KCHOTBOAT 06-17-2003 10:23 AM
I would like to check your boat out sometime. I work at JCCC so I am just down the road.
liquid lounge 06-17-2003 11:41 AM
KC- Anytime....541-0641...ask for berg. I'm on 99th street between Lackman & Sante fe
KCHOTBOAT 06-17-2003 12:27 PM
How does your Thursday look or sometime next week?
Rich
liquid lounge 06-17-2003 01:25 PM
Thursday is fine...just give me a call:cool:
