-   -   Exhaust Film on Transom?? (https://www.offshoreonly.com/forums/general-q/52886-exhaust-film-transom.html)
Fast Forward 06-22-2003 06:47 AM
Just took the boat out for the 2nd time this year and noticed
a lot of black exhaust film on the transom. It was an evening run and air temp was about 68deg. Would this be a choke issue??
I've always gotten a little but never this bad. Any ideas?
Gary C 06-22-2003 07:54 AM
I have a 260 legend with a carb motor. I noticed the same thing this year. I think it has to do with the weather. Plus I was running the full tank from the winter. I'm gonna fill up with new gas and see if it is the same. I'll use regular as I found that high test causes more black soot. I usually put the boat away with a full tank of hi test.
Fast Forward 06-22-2003 08:28 AM
Gary C. You know I just starting running the higher octane and I don't recall seeing much of any of this last year. As well as I still have a half a tank of old gas from last year. I'm heading out again today so I'm going to fill up with the mid.
Thanks Brian
bobby daniels 06-22-2003 11:19 AM
Alot of it is from maybe still having the winter fuel in the tank
this fuel will not perform well in warmer weather and also the fuel is a year (almost) old ... be sure your choke comes all the way off
And MSD 6AL and coil will relly help this (no I don't work for MSD)
its just good stuff ,leave the thunderbolt on the boat that way you have a spare :D :D :D
Fast Forward 06-22-2003 08:11 PM
Well I topped it off with fresh mid grade and she came in pretty clean. I think you guys were right on the old fuel. It was in the mid 80's as well. What a beautiful day on the lake!! The first nice weekend this year.
Vyper340 06-23-2003 06:42 AM
What engines and which boat?
Fast Forward 06-23-2003 07:02 AM
I've got a 1993 Conquest with a 454 mag.
Outlawcowgirl 06-23-2003 11:38 AM
I have soot on the transom every time I take her out. I just assumed it was from the carb that we have on her.
And we almost always put the higher octane fuel in her too.
mlitefan 06-23-2003 12:05 PM
So is it better to run 89 octane in a a 502 MAG MPI? I run 92 or 93.
Sure would save a little money over time....Hey, a case of beer is a case of beer!!!:D
Fast Forward 06-23-2003 12:19 PM
I can only tell you this much. It came in with a dark gray transon with 93 octane with an air temp of 68deg. And with 89 octane and a near 85 edg temp she was nearly clean. I do think the air temp had something to do with it but just not sure how much??
